[mapguide-internals] Installer progress
Gunter Becker gunter.becker at csogis.de
Fri Apr 24 18:19:33 EDT 2009
Jason, I have to correct myself. I've set the environmental variable to
"C:\Programme\.." and realized that the MapGuide Server could be started in
interacive mode. Then I switched back to "C:\Program Files\.." and tested
again the interactive mode and this also worked for me. Maybe I've done
something wrong the last time I try.
Nevertheless, the service didn't start in both cases.
I will give FileMon a try as soon as possible!
Gunter
Jason Birch wrote:
> I could be wrong on any of this, but I think the initialization of the
> coordinate system calls SetDefaultDictionaryDirAndFileNames which does the
> following:
> Gets the default dictionary dir (MENTOR_DICTIONARY_PATH or the autodesk
> string if that isn't set)
> Gets the default CS dictionary filename ("Coordsys.CSD")
> Gets the default Datum dictionary filename ("Datums.CSD")
> Gets the default Ellipsoid dictionary filename ("Elipsoid.CSD")
> Gets the default Ellipsoid dictionary filename ("Category.CSD")
> Then it goes and sets each of them to test validity.
> If your MENTOR_DICTIONARY_PATH is set properly, and all of these files
> exist, then either MapGuide isn't able to read the environmental variable
> properly, or something is going wrong in the validation steps for the
> directory or the individual files.  This is starting to get a bit
> technical, but would it be possible for you to use something like
> SysInternals' FileMon to see what's going on in the Program Files/OSGeo
> directory during MapGuide startup?
> As an aside, I was a bit confused by this code, since the default
> dictionary names appear to be set as part of each dictionary's
> initialization, and their content validated when SetDictionaryDir is
> called.  SetDefaultDictionaryDirAndFileNames seems to be more of a "reset"
> function than an initialization function.  Wouldn't it be sufficient to
> just call GetDefaultDictionaryDir and SetDictionaryDir?
> Jason
> -----Original Message-----
> From: Gunter Becker
> Sent: April-24-09 9:18 AM
> Subject: RE: [mapguide-internals] Installer progress
> Yes the default ist "Programme". But I thought that it is just like a
> virtual
> path since Windows Vista / Windows Server 2008. Each time when I install a
> program I'm asked to install it to "C:\Program Files\..." and I say: OK.
> In
> former Windows version there were often 2 two folders: C:/Program Files
> and
> C:/Programme. But these days are gone!
> By the way, I already tried "Programme" in the settings and got the same
> message!
> Gunter
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-progress-tp2675328p2700164.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
