[mapguide-internals] RFC 72 - Commercial Map Service Support
Chris Claydon
chris.claydon at autodesk.com
Thu Aug 6 12:26:42 EDT 2009
For the case of Google base maps, a unique key is required that works specifically on your site. If you choose to use this feature on anything other than a localhost server, you'll need to obtain such a key from Google, and in so doing you will need to declare that your site meets the required criteria. The RFC simply enables the technology. It will be up to the site administrator to ensure that she complies with any requirements laid out by the commercial map vendors.
Chris.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, August 06, 2009 5:48 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] RFC 72 - Commercial Map Service Support
as nearly all mapguide sites annoyingly require a password, even for
anonymous access,
doesn't this break the terms of service for some commercial providers?
z
On Thu, Aug 6, 2009 at 7:06 PM, Arthur Liu<arthur.liu at autodesk.com> wrote:
> Hi All,
> RFC 72 for Commercial Map Service Support is ready for review now. Your questions and comments are appreciated.
> Link: https://trac.osgeo.org/mapguide/wiki/MapGuideRfc72
> Thanks,
> Arthur
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
