[mapguide-internals] mapguide-2.0.2.3011.tar.gz
Tom Fukushima tom.fukushima at autodesk.com
Tue Aug 11 14:16:05 EDT 2009
If you can't get around the problem with unzipping these files on Windows, I suggest getting the source directly from subversion using the tags/MAPGUIDE2.0.2 tag.  The source will not have the correct version stamps in the files but perhaps someone who knows off hand can describe how to set these correctly.
The subversion location is http://svn.osgeo.org/mapguide/tags/MAPGUIDE2.0.2.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of pcardinal
Sent: Tuesday, August 11, 2009 9:11 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] mapguide-2.0.2.3011.tar.gz
OS: Windows XP and Windows Vista
Unzipping utilities : WinRar and WinZip
How come there is so many errors when unzipping mapguide-2.0.2.3011.tar.gz?
Example:
twice the file "mov" in
\mapguide-2.0.2.3011\mapguide-2.0.2\Oem\fusionframework\fusion\trunk\templates\mapguide\slate\theme\default\img
with two different sizes.
Where can I find a good zip file?
Pierre
View this message in context: http://n2.nabble.com/mapguide-2.0.2.3011.tar.gz-tp3424462p3424462.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
