[mapguide-internals] mapguide-2.0.2.3011.tar.gz
Jason Birch
Jason.Birch at nanaimo.ca
Tue Aug 11 14:34:29 EDT 2009
We should probably update the build instructions to reference SVN instead of the TAR file. It's way easier that way for developers to contribute patches back to the project, indicate what file they're having problems with, etc.
Pierre, there's a VBS utility in the trunk of MgDev that allows you to set the version number prior to compiling. It requires Collabnet SVN (or another command line SVN tool) on the path. Running it will give you the syntax, but it's basically:
cscript updateversion.vbs /major:2 /minor:1 /point:0
You can download it by clicking on the "Original Format" link at the bottom of this page:
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/updateversion.vbs
I'd also recommend using MapGuide 2.1 branch at this point over 2.0.x. It's more stable and faster.
Jason
-----Original Message-----
Sent: Tuesday, August 11, 2009 11:16 AM
Subject: RE: [mapguide-internals] mapguide-2.0.2.3011.tar.gz
If you can't get around the problem with unzipping these files on Windows, I suggest getting the source directly from subversion using the tags/MAPGUIDE2.0.2 tag. The source will not have the correct version stamps in the files but perhaps someone who knows off hand can describe how to set these correctly.
The subversion location is http://svn.osgeo.org/mapguide/tags/MAPGUIDE2.0.2.
More information about the mapguide-internals
