[mapguide-internals] mapguide-2.0.2.3011.tar.gz
pcardinal
pierre.cardinal at sympatico.ca
Tue Aug 11 18:16:55 EDT 2009
You're right about SVN but I am following the advice in the build.bat under
trunk\MgDev
rem For a "cleaner" build experience, run this script from an exported copy
of the
rem MapGuide source code (ie. without subversion folders).
Does my understanding is wrong about trying to use the file
mapguide-2.0.2.3011.tar.gz?
Effectively I rather use 2.1
Pierre
Jason Birch wrote:
> We should probably update the build instructions to reference SVN instead
> of the TAR file. It's way easier that way for developers to contribute
> patches back to the project, indicate what file they're having problems
> with, etc.
> Pierre, there's a VBS utility in the trunk of MgDev that allows you to set
> the version number prior to compiling. It requires Collabnet SVN (or
> another command line SVN tool) on the path. Running it will give you the
> syntax, but it's basically:
> cscript updateversion.vbs /major:2 /minor:1 /point:0
> You can download it by clicking on the "Original Format" link at the
> bottom of this page:
> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/updateversion.vbs
> I'd also recommend using MapGuide 2.1 branch at this point over 2.0.x.
> It's more stable and faster.
> Jason
> -----Original Message-----
> From: Tom Fukushima
> Sent: Tuesday, August 11, 2009 11:16 AM
> Subject: RE: [mapguide-internals] mapguide-2.0.2.3011.tar.gz
> If you can't get around the problem with unzipping these files on Windows,
> I suggest getting the source directly from subversion using the
> tags/MAPGUIDE2.0.2 tag. The source will not have the correct version
> stamps in the files but perhaps someone who knows off hand can describe
> how to set these correctly.
> The subversion location is
> http://svn.osgeo.org/mapguide/tags/MAPGUIDE2.0.2.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/mapguide-2.0.2.3011.tar.gz-tp3424462p3427209.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
