[mapguide-internals] mapguide-2.0.2.3011.tar.gz
Jason Birch
Jason.Birch at nanaimo.ca
Tue Aug 11 18:50:10 EDT 2009
Ah...
I believe that's referring to the "svn export" command. It basically copies all of the files into a different location but without the .svn directories.
The new windows build scripts (build.bat) allow you to build in place and then "install" into a clean directory structure. I personally prefer this approach, as it means that I'm always building from a "live" location.
The "clean" action on the build script is pretty decent, but if I need a really clean environment I just
use the Perl svn-clean script (1) which removes all files that aren't under version control. Have to be careful with this though if you're doing any new development as it can blow away your new local files.
1. svn-clean: http://svn.collab.net/repos/svn/trunk/contrib/client-side/svn-clean
Jason
-----Original Message-----
Sent: Tuesday, August 11, 2009 3:17 PM
Subject: RE: [mapguide-internals] mapguide-2.0.2.3011.tar.gz
You're right about SVN but I am following the advice in the build.bat under
trunk\MgDev
rem For a "cleaner" build experience, run this script from an exported copy
of the
rem MapGuide source code (ie. without subversion folders).
Does my understanding is wrong about trying to use the file
mapguide-2.0.2.3011.tar.gz?
Effectively I rather use 2.1
More information about the mapguide-internals
