[mapguide-internals] interim build
Jason Birch
Jason.Birch at nanaimo.ca
Wed Aug 12 04:43:27 EDT 2009
Does the commit from a couple days ago address the MapGroup handling?
http://trac.osgeo.org/fusion/ticket/228
The widget structure and Jx changed considerably changed between Fusion 1.1 and Fusion 2.0, so I wouldn't be surprised if there were a few backwards incompatibilities. A bit more on these changes here:
http://n2.nabble.com/Jx-API-Update-td2062075.html#a2062075
Jason
________________________________________
Sent: Wednesday, August 12, 2009 1:37 AM
Subject: RE: [mapguide-internals] interim build
Yes, in a way:
For some reason, the toolbar menus do not have the function setTooltip()
anymore - I've set them in my application definition with Mapguide Studio
2009
And furthermore the is an issue with reading all MapGroups into the MapMenu
For both of these issue I'll submit a ticket with workaround patch...
Andreas
More information about the mapguide-internals
