[mapguide-internals] interim build
Andreas Morf a.morf at fkl.ch
Wed Aug 12 04:58:25 EDT 2009
Hhm, seems that madair did the same work yesterday...
But for the tooltip-issue I didn't find a fix so far.
Andreas
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-
> internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Wednesday, August 12, 2009 10:43 AM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] interim build
> Does the commit from a couple days ago address the MapGroup handling?
> http://trac.osgeo.org/fusion/ticket/228
> The widget structure and Jx changed considerably changed between Fusion
> 1.1 and Fusion 2.0, so I wouldn't be surprised if there were a few
> backwards incompatibilities.  A bit more on these changes here:
> http://n2.nabble.com/Jx-API-Update-td2062075.html#a2062075
> Jason
> ________________________________________
> From: Andreas Morf
> Sent: Wednesday, August 12, 2009 1:37 AM
> Yes, in a way:
> For some reason, the toolbar menus do not have the function
> setTooltip()
> anymore - I've set them in my application definition with Mapguide
> Studio
> 2009
> And furthermore the is an issue with reading all MapGroups into the
> MapMenu
> For both of these issue I'll submit a ticket with workaround patch...
> Andreas_______________________________________________
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
