[mapguide-internals] Apache Service event 3299
pcardinal
pierre.cardinal at sympatico.ca
Mon Aug 17 16:26:19 EDT 2009
Hi Jackie,
I am on 32-bit. And effectively, depends.exe complains on MgHttpHandler.dll
Error: At least one required implicit or forwarded dependency was not found.
Warning: At least one delay-load dependency module was not found.
Warning: At least one module has an unresolved import due to a missing
export function in a delay-load dependent module.
MSVCR90.DLL Error opening file. Le fichier spécifié est intouvable(2).
[translation: the file is not found]
IESHIMS.DLL Error opening file. Le fichier spécifié est intouvable(2).
What is the solution?
Regards,
Pierre
Jackie Ng wrote:
> Run depends.exe on MgHttpHandler.dll and see if it complains about any
> dlls it can't find. Also, are you on a 32-bit or 64-bit windows?
> - Jackie
> pcardinal wrote:
>> Hi,
>> After installing MapGuideOpenSource-2.1.0.4114-Unofficial.exe, I got the
>> following event (error) when I try to start the service
>> ApacheMapGuide2.1.
>> (OS : Vista or XP)
>> 3299
>> 2
>> 0
>> 0x80000000000000
>> 105699
>> Application
>> GeoLys
>> The Apache service named
>> reported the following error:
>> httpd.exe: Syntax error on line 127 of J:/Program
>> Files/OSGeo/MapGuide/Web/Apache2/conf/httpd.conf: Cannot load J:/Program
>> Files/OSGeo/MapGuide/Web/Php/MgHttpHandler.dll into server: La
>> proc\xe9dure sp\xe9cifi\xe9e est introuvable.
>> line 127 is LoadFile "J:/Program
>> Files/OSGeo/MapGuide/Web/Php/MgHttpHandler.dll"
>> Somebody have a clue?
>> Pierre
View this message in context: http://n2.nabble.com/Apache-Service-event-3299-tp3452312p3461843.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
