[mapguide-internals] Apache Service event 3299
Jason Birch Jason.Birch at nanaimo.ca
Mon Aug 17 16:44:25 EDT 2009
Haven't seen this before, so not sure what the solution is.
You could try re-installing the MS VC++ Runtime libraries, but those are normally not detected by depends.
Is J: a locally attached hard drive?  Is it possible to try installing under C:\Apps or something like that to rule out networking and locale-related problems?
Jason
-----Original Message-----
Sent: Monday, August 17, 2009 1:26 PM
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] Apache Service event 3299
I am on 32-bit. And effectively, depends.exe complains on  MgHttpHandler.dll
Error: At least one required implicit or forwarded dependency was not found.
Warning: At least one delay-load dependency module was not found.
Warning: At least one module has an unresolved import due to a missing
export function in a delay-load dependent module.
MSVCR90.DLL Error opening file. Le fichier spécifié est intouvable(2).
[translation: the file is not found]
IESHIMS.DLL Error opening file. Le fichier spécifié est intouvable(2).
What is the solution?
More information about the mapguide-internals mailing list
