[mapguide-internals] Maestro Expression Editor Syntax
Traian Stanev
traian.stanev at autodesk.com
Tue Aug 25 10:50:15 EDT 2009
Try:
Postedname='Third Street'
Single quotes for strings. Double quotes makes it think that it is a column name.
Traian
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-
> bounces at lists.osgeo.org] On Behalf Of Tysonk
> Sent: Tuesday, August 25, 2009 10:48 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] Maestro Expression Editor Syntax
> Hello,
> I'm trying to compare String expressions in Maestro's Expression Editor to
> style a layer in a certain way. I have a attribute "Postedname" for the
> streets in my map. Now I want to style the streets with a certain name, in a
> different way. For, example I want all the streets with the name "Third
> Street" to be in a thicker line than the rest.
> My problem is that I'm not sure of the exact syntax to do this. I've tried
> things such as:
> Postedname="Third Street"
> Postedname Equals "Third Street"
> Postedname.equals("Third Street")=1
> Postedname.compareto("Third Street")=1
> ....But to no avail. I was wondering if someone could help me out with
> explaining the correct way to compare/evaluate two Strings in Maestro's
> Expression Editor.
> Thanks!
> View this message in context: http://n2.nabble.com/Maestro-Expression-
> Editor-Syntax-tp3510365p3510365.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
