[mapguide-internals] Maestro Expression Editor Syntax
Tysonk Tyson.Konkin at MeridianSurveys.ca
Tue Aug 25 10:54:11 EDT 2009
Thanks Traian, that worked perfectly!
I was trying tirelessly to get this working yesterday, and I could have
sworn I tried single quotes as well, but I guess not.
Thanks again!
Traian Stanev wrote:
> Try:
> Postedname='Third Street'
> Single quotes for strings. Double quotes makes it think that it is a
> column name.
> Traian
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org
>> [mailto:mapguide-internals-
>> bounces at lists.osgeo.org] On Behalf Of Tysonk
>> Sent: Tuesday, August 25, 2009 10:48 AM
>> To: mapguide-internals at lists.osgeo.org
>> Subject: [mapguide-internals] Maestro Expression Editor Syntax
>> Hello,
>> I'm trying to compare String expressions in Maestro's Expression Editor
>> to
>> style a layer in a certain way. I have a attribute "Postedname" for the
>> streets in my map. Now I want to style the streets with a certain name,
>> in a
>> different way. For, example I want all the streets with the name "Third
>> Street" to be in a thicker line than the rest.
>> My problem is that I'm not sure of the exact syntax to do this. I've
>> tried
>> things such as:
>> Postedname="Third Street"
>> Postedname Equals "Third Street"
>> Postedname.equals("Third Street")=1
>> Postedname.compareto("Third Street")=1
>> ....But to no avail. I was wondering if someone could help me out with
>> explaining the correct way to compare/evaluate two Strings in Maestro's
>> Expression Editor.
>> Thanks!
>> View this message in context: http://n2.nabble.com/Maestro-Expression-
>> Editor-Syntax-tp3510365p3510365.html
>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Maestro-Expression-Editor-Syntax-tp3510365p3510434.html
More information about the mapguide-internals mailing list
