[mapguide-internals] RFC 81 is ready for review
Tom Fukushima
tom.fukushima at autodesk.com
Fri Aug 28 15:50:06 EDT 2009
Hi Jackie,
RFC 81 needs more details about the UI, use cases, limitations and implementation. I believe that it will be rewritten or withdrawn.
The UI (as I understand it) for RFC 81 is similar with RFC 71 in that it handles showing properties for multiple selections. But the feature inspector (RFC 81) is more for doing other types of analysis such as reselecting, or zooming to features. I think that the "feature inspector" is more for an advanced user, and the "Properties" widget will still be important. So I don't think that you should suspend or cancel the work on RFC 71.
Cheers
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, August 24, 2009 9:57 AM
To: mapguide-internals at lists.osgeo.org
Subject: RE: [mapguide-internals] RFC 81 is ready for review
There's no point in having redundant functionality. This RFC seems to cover
RFC 71 and more. I have no qualms about suspending/cancelling my work on RFC
71.
- Jackie
Buddy Hu wrote:
> Hi Kenneth, Thanks for your reply!
> About the overlap with RFC 71, I think we don't make any changes to the
> existing Selection Panel. If Jackie want to introduce the Selection Panel
> to the AJAX view, I am pleasure to see this happens. If not, I think the
> Feature Inspector panel will cover some functionalities of the Selection
> Panel.
> For the typo of "Inverse Selection", I will update it later. Thanks for
> your good catch.
> And I don't think we need any server or Webserver code changes for this
> RFC. I will clarify these in the "Implications" part.
> And I'm not intent to support the sort or filter for the properties now.
> For the Gzip, we get this suggestion from Paul Spencer. I didn't do any
> test for this yet. For more details, you can check the mail I attached.
> Thanks for your reply again! I will update my RFC and post it again.
> -Buddy
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth
> Skovhede, GEOGRAF A/S
> Sent: Friday, August 21, 2009 4:04 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] RFC 81 is ready for review
> This overlaps a bit with RFC 71:
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc71
> At least the tree for display in the AJAX viewer should be present
> there, and I belive Jackie has developed this already?
> There is a slight spelling error in the "Inverse selection" menu item.
> Are there any changes required in the server code, or is this done with
> the current selection system?
> There has been questions about the order of properties, some want them
> sorted, some want them as is, will there be an option to select sort
> modus?
> To use GZip compression, is it possible to just serve the .gz file or
> does it require a webserver change to supply the compression header?
> I seem to recal that some browsers do not support GZip compression, and
> the served file should obey the compression flag to ensure compatibility.
> If a webserver change is required, will the change include maintenance
> for the installer?
> The test plan should include testing with a range of browsers.
> I am overall positive, the preview looks cool, and the addition is
> sorely needed.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Buddy Hu skrev:
>> Hi All,
>> The RFC 81- Add a new widget Feature Inspector is ok for review.
>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc81
>> Any comments will be appreciated.
>> Thanks,
>> -Buddy Hu
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/RFC-81-is-ready-for-review-tp3485127p3504295.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
