[mapguide-internals] Contact with Autodesk Developers.
Andy Morsell amorsell at spatialgis.com
Mon Dec 14 14:31:26 EST 2009
It's unclear exactly what you are proposing to Autodesk.  Are you looking for
a job?  Are you proposing to perform some of this work as a contractor?  Do
you just want to develop on the MapGuide Open Source code and contribute to
it?  If the latter, anyone can contribute to the source code as long as they
go through the process to become a contributor:
http://mapguide.osgeo.org/developer.html
Thanks,
Andy
Carl Jokl wrote:
> Dear All
> I wanted to see if any of the Autodesk based MapGuide developer team
> members are listening to this forum and whether one of them is willing to
> let me get in touch with them.
> The situation is that after almost 2 years of working at Keynetix I am
> leaving to pursue a research position. I could at this point just walk
> away from all things MapGuide but having worked with it for the best part
> of 2 years I have been quite heavily invested in trying to make it work in
> practice. While working for Keynetix the pressures of deadlines and the
> work that has needed to be done has meant I haven't been able to be
> involved in the open source development of MapGuide because the time and
> budget simple would not allow me to do so. Once I leave Keynetix I will no
> longer be constrained by Keynetix budgets or deadlines and would be able
> to determine for myself the degree to which I could be involved in the
> project.
> A lot of my work has involved trying to sidestep any problems or
> limitations with MapGuide or FDO on the outside within the MapGuide
> framework I worked on for Keynetix however I believe I could most likely
> achieve better success addressing issues from inside the MapGuide
> framework than outside.
> Autodesk is a large organisation. I have already submitted a proposal to
> them through the business side but have not as yet heard anything. I might
> be more successful if I could just start talks with someone on the
> development team at Autodesk to discuss my proposals. I have an ADN
> account but this isn't a support request as such.
> Is anyone from Autodesk listening?
> Carl
View this message in context: http://n2.nabble.com/Contact-with-Autodesk-Developers-tp4163489p4166196.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
