[mapguide-internals] Advanced stylization - global parameters
	for compound symbols?
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Wed Dec 16 18:53:45 EST 2009
Another way to make it work is to use the same name for each child symbol in the compound.  Then the override gets applied to all child symbols with that name and that parameter ID.
Keep in mind that if every child symbol in a compound has different parameter names then that increases the number of things the UI needs to be able to let the user control, whether at a global level or individual level.  So for example if you want to individually control the color of two separate child symbols then use different parameter names for each one.  But if you want the colors of both to always be the same then use the same parameter name.
Making the symbol name optional in the override seems like a reasonable idea.  To avoid a schema change (the SymbolName element is currently required) we could simply say that if the name is blank than it gets applied to all parameters with that identifier name.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, December 16, 2009 4:12 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Advanced stylization - global parameters for compound symbols?
Has any thought been given to a mechanism for setting a parameter override
for a compound symbol at the global level and having it cascade down to all
of the simple symbols within?
I can think of a couple ways of doing this:
 - Make specification of the symbol name optional in the layer's override
declaration, and have it apply to all parameters sharing that identifier
within child simple symbols
 - Add some explicit mapping functionality to the compound symbol
declaration
Is there a mechanism for this that I'm missing?  Is this a bad idea?  I've
run across a few cases already where I want to set the same colour and
weight across a few different parts of a compound symbol, and getting
annoyed having to set them all in the layer definition.  If we ever do get a
GUI for this it will be a bit of a mess in these cases...
Jason
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
