[mapguide-internals] RE: GDAL stability in MGOS 2.1
Trevor Wekel
trevor_wekel at otxsystems.com
Thu Dec 31 13:14:05 EST 2009
Hi Frank,
I am glad to see you are interested. I will need to do some investigation to determine where the instability is coming from. If I do find something in GDAL, I think it would be good to add an additional test to the GDAL test suite. It would help to ensure GDAL Provider stability from release to release. Maybe I'm a bit jaded but all too often the phrase "if it isn't tested, it's probably broken" seems to apply when working with complex code bases.
I can certainly help out with code changes and test suite improvements. Let's keep in touch. Hopefully my little MapGuide/GDAL stability and performance initiative won't drag on too long.
Thanks,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
Sent: December 31, 2009 11:04 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] RE: GDAL stability in MGOS 2.1
Trevor Wekel wrote:
> Hi everyone,
> Under the assumption that no else is really keen to dig around in MapGuide and GDAL, I have added an "Initiatives" page to my website. I will make an official funding request to the user list tomorrow if no one voices any concerns.
> http://www.otxsystems.com/community-initiatives.html
> Yeah. I actually like raster. Weird...
Trevor,
Not so weird!
I would note that if folks can trigger the stability problems via
direct FDO calls, I'm willing to spend some time digging into it. Something
like an additional test in the test suite or a small sample program calling
into FDO. Something I can run without mapguide.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
