[mapguide-internals] Branch of MapGuide Open Source for Autodesk
    Jason Birch
    Jason.Birch at nanaimo.ca
    Thu Jan 22 11:39:53 EST 2009
I have no problem with the concept, but the location seems a bit odd.
Right now Autodesk pretty much "owns" the project and I absolutely see
the need for this from their point, but are we willing to do the same
for other contributors that need their own branches/tags over time?
I think I would prefer to see this done in a different top-level tree.
For GDAL, for instance, Frank appears to maintain (have maintained?) a
custom branch of GDAL for ESRI here:
http://svn.osgeo.org/gdal/sandbox/warmerdam/1.4-esri/
How about we have a policy of allowing contributors to set up areas for
custom trunks/tags/whatever under a different root structure?  I'm not
sure that sandbox is the right term for this, but maybe something like
http://svn.osgeo.org/mapguide/custom/adsk/branches/2.1/
http://svn.osgeo.org/mapguide/custom/adsk/tags/2.1/
Where "custom" could be replaced with the word of your choice ("ext",
"sandbox",?)
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: January-22-09 7:46 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Branch of MapGuide Open Source for
Autodesk
Hi Haris,
It will be for Autodesk, I do not have plans to use it for any MapGuide
Open Source releases.  The MapGuide Open Source developers outside of
Autodesk can feel free to completely ignore the branch.
Regards,
Tom
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Thursday, January 22, 2009 5:20 AM
Autodesk
This branch will be for MG Enterprise or it will be some version of
MapGuide ?
Haris
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Thursday, January 22, 2009 10:48 AM
Subject: Re: [mapguide-internals] Branch of MapGuide Open Source for
Autodesk
It obviously mixes some organizational stuff, but since Autodesk is the
main contributer, I see no problem.
As a bonus it should get a lot easier to determine exactly what fixes
are in place for the Autodesk Enterprise releases.
+1 Kenneth.
Regards, Kenneth Skovhede, GEOGRAF A/S
Tom Fukushima skrev:
> Hi,
> I would like to create a branch from trunk that will be for Autodesk's
use.   Similar to how Fusion's fusion2-mg21 branch is basically for
MapGuide's use.  I plan to put it at branches/adsk2.1.
> It will be like any other branch in that all fixes that go into it
will also be merged into other branches.
> Comments, concerns, questions?
> Regards,
> Tom
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
