[mapguide-internals] Branch of MapGuide Open Source for Autodesk
Tom Fukushima
tom.fukushima at autodesk.com
Thu Jan 22 12:23:32 EST 2009
I like this idea much better than mine. I don't any problem with the naming that you propose so I would like to go with that.
Thanks
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Thursday, January 22, 2009 9:40 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Branch of MapGuide Open Source for Autodesk
I have no problem with the concept, but the location seems a bit odd.
Right now Autodesk pretty much "owns" the project and I absolutely see
the need for this from their point, but are we willing to do the same
for other contributors that need their own branches/tags over time?
I think I would prefer to see this done in a different top-level tree.
For GDAL, for instance, Frank appears to maintain (have maintained?) a
custom branch of GDAL for ESRI here:
http://svn.osgeo.org/gdal/sandbox/warmerdam/1.4-esri/
How about we have a policy of allowing contributors to set up areas for
custom trunks/tags/whatever under a different root structure? I'm not
sure that sandbox is the right term for this, but maybe something like
http://svn.osgeo.org/mapguide/custom/adsk/branches/2.1/
http://svn.osgeo.org/mapguide/custom/adsk/tags/2.1/
Where "custom" could be replaced with the word of your choice ("ext",
"sandbox",?)
Jason
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: January-22-09 7:46 AM
Autodesk
Hi Haris,
It will be for Autodesk, I do not have plans to use it for any MapGuide
Open Source releases. The MapGuide Open Source developers outside of
Autodesk can feel free to completely ignore the branch.
Regards,
Tom
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Thursday, January 22, 2009 5:20 AM
Autodesk
This branch will be for MG Enterprise or it will be some version of
MapGuide ?
Haris
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Thursday, January 22, 2009 10:48 AM
Subject: Re: [mapguide-internals] Branch of MapGuide Open Source for
Autodesk
It obviously mixes some organizational stuff, but since Autodesk is the
main contributer, I see no problem.
As a bonus it should get a lot easier to determine exactly what fixes
are in place for the Autodesk Enterprise releases.
+1 Kenneth.
Regards, Kenneth Skovhede, GEOGRAF A/S
Tom Fukushima skrev:
> Hi,
> I would like to create a branch from trunk that will be for Autodesk's
use. Similar to how Fusion's fusion2-mg21 branch is basically for
MapGuide's use. I plan to put it at branches/adsk2.1.
> It will be like any other branch in that all fixes that go into it
will also be merged into other branches.
> Comments, concerns, questions?
> Regards,
> Tom
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
