[mapguide-internals] RFC 77 - Create Feature Source is ready for review
Leaf Li leaf.li at autodesk.com
Thu Jul 9 04:56:39 EDT 2009
Good questions.
1. It will support SHP and SQLite only because ORG & DGAL FDO provider is a read-only provider. It doesn't support FdoICreateStore command. So we can't do it.
2. For method GetFileOrFolderName(), folder name is used for SHP only currently. For example, if you want to create multiple shp files, a folder name need to be specified instead of a file name. Actually file or folder name here are the relative path file or folder name. All created files are located in Respositories\Library\DataFiles\xxxxxxxxxxxxxx\.
Thanks,
Leaf Li
More information about the mapguide-internals mailing list
