[mapguide-internals] Maestro and compatibility with previous
mapguide versions.
Gabriele Monfardini
gabrimonfa at gmail.com
Thu Jul 23 05:38:34 EDT 2009
> Generally I would like Maestro to be compatible with all versions of
> MapGuide.
Great.
> But versions older than 1.2 are not supported, and once 2.1 comes out,
> I think 1.2 support could be deprecated.
> And by deprecated I mean, just not accept tickets fixing issues with that
> version.
Please continue supporting version 1.2 if it's possible (and not too much work).
Some people is still using 1.2 due to some problem with 2.x (eg.
horrible compilation problem under GNU/Linux or problems with new
Postgis provider).
And Maestro is a great tool to work with.
> So far, MapGuide has not broken any backwards compatibility, so
> when implementing a new feature everything else should work fine anyway.
> I only have access to a few versions of MapGuide, so I generally only test
> with the most recent release (2.1 atm).
Well, obviously this is fine.
Until now 2.x API is largely the same as 1.2 so no problems at all.
Thank you for your work
Gabriele
More information about the mapguide-internals
