[mapguide-internals] Maestro and compatibility with previous
mapguide versions.
Trevor Wekel
trevor_wekel at otxsystems.com
Thu Jul 23 15:41:32 EDT 2009
That's fair. I was just trying to avoid the potential of a spaghetti code situation by trying to support too many versions of MapGuide in a single executable. For the most part, I suspect the new features would just be "greyed out" if the MapGuide version is too low. But I am curious about changes to schema (map definition, layer definition, etc.). These changes could have an impact on the Maestro UI.
Perhaps it's not such a big deal.
Thanks,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Thursday, July 23, 2009 1:33 PM
To: 'mapguide-internals at lists.osgeo.org'
Subject: Re: [mapguide-internals] Maestro and compatibility with previous mapguide versions.
I'd be hesitant to see maestro in lock-step with mapguide. I think that once Kenneth gets to a 1.0 release that it should be branched/tagged, and that version support should be explicit on the download page, but I'd hate to see a hard and fast 1:1 relationship between maestro and MapGuide if it can be helped. I like how Haris is supporting multiple fdo api versions of his oracle provider so users aren't forced to upgrade to get fixes, etc.
----- Original Message -----
From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
Sent: Thu Jul 23 12:21:17 2009
Subject: RE: [mapguide-internals] Maestro and compatibility with previous mapguide versions.
Hey guys,
I was just looking at MapGuide subversion vault and it seems as though Maestro only has a single stream under http://svn.osgeo.org/mapguide/trunk/Tools/Maestro. Is the intent to always have Maestro trunk support all releases of MapGuide? This would currently include 1.2, 2.0, and 2.1 and likely 2.2 next year.
This will make coding and validation for new releases more complicated due to the "all releases supported" constraint. Next year's Maestro will have to be coded to ensure that 1.2, 2.0, 2.1, and 2.2 work. In addition, Maestro will have to be testing against all of these versions of MapGuide on both Windows and Linux. That's eight different combinations to validate.
It might be simpler from a coding and testing perspective if Maestro used a branch strategy similar to the one used for MapGuide. In other words, Maestro could have a separate branch for 1.2, 2.0, 2.1 and 2.2. Previous releases (1.2, 2.0) would only receive critical bug fixes and the most current release would get all the new features. Since there are different versions of Maestro available, 100% backward compatibility is no longer a requirement. Users could just install the version(s) of Maestro they required. In addition, development and testing should be easier because Maestro would only be targeting a specific release of MapGuide.
Any thoughts?
Thanks,
Trevor
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, July 23, 2009 6:23 AM
it would be good to have some sort of register of users by version n api...
On Thu, Jul 23, 2009 at 9:41 PM, Jackie Ng<jumpinjackie at gmail.com> wrote:
> The flipside to that is that the need to support 1.2 may hinder
> certain enhancements from being implemented. Which is why I raised the
> original question.
> - Jackie
> Gabriele Monfardini wrote:
>>> Generally I would like Maestro to be compatible with all versions of
>>> MapGuide.
>> Great.
>>> But versions older than 1.2 are not supported, and once 2.1 comes
>>> out, I think 1.2 support could be deprecated.
>>> And by deprecated I mean, just not accept tickets fixing issues with
>>> that version.
>> Please continue supporting version 1.2 if it's possible (and not too
>> much work).
>> Some people is still using 1.2 due to some problem with 2.x (eg.
>> horrible compilation problem under GNU/Linux or problems with new
>> Postgis provider).
>> And Maestro is a great tool to work with.
>>> So far, MapGuide has not broken any backwards compatibility, so when
>>> implementing a new feature everything else should work fine anyway.
>>> I only have access to a few versions of MapGuide, so I generally
>>> only test with the most recent release (2.1 atm).
>> Well, obviously this is fine.
>> Until now 2.x API is largely the same as 1.2 so no problems at all.
>> Thank you for your work
>> Gabriele
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> http://n2.nabble.com/Maestro-and-compatibility-with-previous-mapguide-
> versions.-tp3307965p3309041.html Sent from the MapGuide Internals
> mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
