[mapguide-internals] Improving DescribeSchema by exposing schema info as tables
Zac Spitzer zac.spitzer at gmail.com
Mon Jul 27 06:39:56 EDT 2009
Just been playing around with describe schema as xml, it's
quite a complex experience when I compare it to approaches
used in other data access layers / databases.
Having system tables which can be queried,  along the lines of oracle tables,
ie "USER_TABLES and USER_TAB_COLUMNS" is a lot simpler to work with
essentially the information returned is pretty flat and simple rather than
the complex structure exposed via the xml
thoughts?
z
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
