[mapguide-internals] Motion: vote RFC 77 - Create Feature Source
Paul Spencer
pspencer at dmsolutions.ca
Tue Jul 28 06:17:55 EDT 2009
+1 Paul
On 28-Jul-09, at 3:39 AM, Kenneth Skovhede, GEOGRAF A/S wrote:
> +1 Kenneth
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Jason Birch skrev:
>> +1 Jason
>> I would suggest that the inline (and generated) docs for
>> MgCreateSdfParams have specific mention that it also supports
>> others. Future work should be done to deprecate this and use a more
>> generic name.
>> ----- Original Message -----
>> From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org
>> To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
>> Sent: Mon Jul 27 21:27:45 2009
>> Subject: [mapguide-internals] Motion: vote RFC 77 - Create Feature
>> Source
>> Hi,
>> I motion for a vote on
>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc77
>> +1 Tom
>> Here is the summary of the review:
>> 1. It will support SHP and SQLite only because ORG & DGAL FDO
>> provider is a read-only provider. It doesn't support
>> FdoICreateStore command. So we can't do it.
>> 2. For method GetFileOrFolderName(), folder name is used for SHP
>> only currently. For example, if you want to create multiple shp
>> files, a folder name need to be specified instead of a file name.
>> Actually file or folder name here are the relative path file or
>> folder name. All created files are located in Respositories\Library
>> \DataFiles\xxxxxxxxxxxxxx\.
>> 1. In implications section, point out specifically that
>> method MgFeatureService::CreateFeatureSourceSQLite will support
>> SHP, SDF and SQLite only because other file-based FDO providers
>> don't support FdoICreateDataStore command.
>> 2. Modify name of the following two methods.
>> a) GetFileOrFolderName -> GetFileName.
>> b) GetFileOrFolderName -> GetFileName.
>> 1. Should the class name be changed? "MgCreateSdfParams" is a bit
>> misleading.
>> Yes. It is a little misleading. However, we can't change it because
>> it may break backward compatibility of current MapGuide Web API.
>> 2. If the provider supports all required calls, will this work with
>> any provider? Eg. if the OGR provider is fixed, or a new provider
>> is made, will the call work, or is there a "supported providers"
>> check?
>> We have to have a supported providers check now. So if some new
>> file-based providers supports FdoICreateStore in the future, we
>> have to do some additional works. The parameters of different
>> providers for command FdoICreateStore is different.
>> MgFileFeatureSourceParams doesn't have a
>> FdoIDataStorePropertyDictionary as FdoICreateStore command. So we
>> can't do it. Moreover, SHP file is created by FdoIApplySchema
>> instead of FdoICreateStore.
>> 3. just wondering if the limitation to file based feature sources
>> is imperative. Maybe its worthwhile to keep the API sufficiently
>> generic to permit easy extensions at a later time.
>> We support file-based feature sources only because of limited
>> resource. Currently API is still generic. MgFeatureSourceParams is
>> a pure virtual class without any members. So we can create a very
>> generic class if we want to support other types of data store in
>> the future.
>> 4. Given the correct connector is available on the used server
>> deployment what's missing to extend that to the generic case?
>> There is no very specific reason that we can't extend it to the
>> generic case. The only reason is we don't have enough resource to
>> support all of providers because it need not only development
>> efforts but also testing efforts.
>> Thanks
>> Tom
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the mapguide-internals
