[mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles using Style Order
scotth at mpowerinnovations.com scotth at mpowerinnovations.com
Thu Jun 25 23:20:41 EDT 2009
I   can make a screen shot of any map of centerlines Ive ever made seems the longer roads segments are vs a hwy that the local roads label trumps the hwy no matter how far down I put he themes rule
-----Original Message-----
Sent: Thursday, June 25, 2009 9:59 PM
To: scotth at mpowerinnovations.com <scotth at mpowerinnovations.com>
Cc: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
Subject: Re: [mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles
	using Style Order
Scott can you log a bug and attach a simple MGP which demonstrates this issue?
z
On Fri, Jun 26, 2009 at 12:53 PM,
scotth at mpowerinnovations.com<scotth at mpowerinnovations.com> wrote:
> LOL stuck key on Windows Mobile phone...last word was disagreeing....
> From: Zac Spitzer <zac.spitzer at gmail.com>
> Sent: Thursday, June 25, 2009 9:36 PM
> To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
>        using Style Order
> At the moment the only way to achieve this is to split the road network out into
> multiple layers which is rather ugly.
> Taking a road network as the example here, it's only at the
> intersections where this
> problem occurs.
> Can some elaborate on how the server currently handles this?
> z
> On Fri, Jun 26, 2009 at 12:28 PM, Walt
> Welton-Lair<walt.welton-lair at autodesk.com> wrote:
>> "Proposed solution: Add support to the rendering engine to render layer styles in ordered passes."
>> I'd like to see some concrete suggestions in the RFC on how to actually do this efficiently.  Just consider a conservative use case - say around 10  rules.
>> Walt
>> ________________________________________
>> From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
>> Sent: Thursday, June 25, 2009 9:29 PM
>> Subject: [mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles using    Style Order
>> I have posted a new RFC
>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc69
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
