[mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles using Style Order
Zac Spitzer zac.spitzer at gmail.com
Thu Jun 25 23:26:03 EDT 2009
have you tried with the 2.1 beta? there are a heap of labelling improvements
http://trac.osgeo.org/mapguide/search?q=labels&noquickjump=1&ticket=on
z
On Fri, Jun 26, 2009 at 1:20 PM,
scotth at mpowerinnovations.com<scotth at mpowerinnovations.com> wrote:
> I   can make a screen shot of any map of centerlines Ive ever made seems the longer roads segments are vs a hwy that the local roads label trumps the hwy no matter how far down I put he themes rule
> -----Original Message-----
> From: Zac Spitzer <zac.spitzer at gmail.com>
> Sent: Thursday, June 25, 2009 9:59 PM
> To: scotth at mpowerinnovations.com <scotth at mpowerinnovations.com>
> Cc: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
> Subject: Re: [mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles
>        using Style Order
> Scott can you log a bug and attach a simple MGP which demonstrates this issue?
> z
> On Fri, Jun 26, 2009 at 12:53 PM,
>> LOL stuck key on Windows Mobile phone...last word was disagreeing....
>> Sent: Thursday, June 25, 2009 9:36 PM
>> To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
>>        using Style Order
>> At the moment the only way to achieve this is to split the road network out into
>> multiple layers which is rather ugly.
>> Taking a road network as the example here, it's only at the
>> intersections where this
>> problem occurs.
>> Can some elaborate on how the server currently handles this?
>> z
>> On Fri, Jun 26, 2009 at 12:28 PM, Walt
>> Welton-Lair<walt.welton-lair at autodesk.com> wrote:
>>> "Proposed solution: Add support to the rendering engine to render layer styles in ordered passes."
>>> I'd like to see some concrete suggestions in the RFC on how to actually do this efficiently.  Just consider a conservative use case - say around 10  rules.
>>> Walt
>>> ________________________________________
>>> From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
>>> Sent: Thursday, June 25, 2009 9:29 PM
>>> Subject: [mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles using    Style Order
>>> I have posted a new RFC
>>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc69
>>> Zac Spitzer -
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>>> mapguide-internals mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> Zac Spitzer -
>> +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
