[mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles
using Style Order
Paul Spencer
pspencer at dmsolutions.ca
Fri Jun 26 09:17:59 EDT 2009
How would someone achieve the desired effect now? From what I
understand (and I am not a power user of mapguide by any standard of
measurement), you would need to create several layer definitions each
with a filter and theme those layers for each road class?
how would performance for:
- for each rule, construct an FDO query filtered by the rule's condition
- render all features using the rule's style
differ from having separate layers?
Yours confusedly ;)
Paul
On 25-Jun-09, at 11:06 PM, Walt Welton-Lair wrote:
> "Can some elaborate on how the server currently handles this?"
> Handles what?
> The current code iterates once over the features (ignore the
> compound line style example). For every feature it evaluates the
> filters defined by the rules (in the order that the rules are
> specified). Once it finds a matching rule it applies its style to
> the feature.
> With compound line styles we make a pass over all the features for
> each line style. So for a compound line style containing M styles
> we make M FDO queries.
> With rendering passes (RFC 29) we also iterate over all the layer's
> features for each rendering pass. The more passes you define the
> more queries you make.
> How to implement your RFC?
> option 1
> - Make a pass over the features for each rule.
> - During each pass only render the features that satisfy the rule
> for that pass.
> - If there are M rules you will make M FDO queries.
> => performance (speed) will be unacceptable for anything more than a
> few themes
> option 2
> - Make one query against all the features, remembering (in memory?)
> all the feature information (attributes / geometry) needed by
> stylization.
> - During the initial pass render the features for the first rule.
> - Iterate over the remaining rules in order, rendering the features
> for each rule.
> => performance (memory use) will be unacceptable for data sources
> containing large numbers of features
> => this approach goes against the MG architecture of not keeping
> feature data in memory during stylization (we already break that
> rule with labels which is what leads to high memory usage spikes for
> some maps)
> option 3
> - Allocate one image per rule.
> - Make one query against all the features, and render each feature
> into the image corresponding to the rule it satisifes.
> - Merge all images at the end.
> => performance (speed + memory) will be unacceptable for anything
> more than a few themes
> option 4
> ________________________________________
> From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org
> ] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
> Sent: Thursday, June 25, 2009 10:36 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] MapGuide RFC 69 - Rendering Layer
> Styles using Style Order
> At the moment the only way to achieve this is to split the road
> network out into
> multiple layers which is rather ugly.
> Taking a road network as the example here, it's only at the
> intersections where this
> problem occurs.
> z
> On Fri, Jun 26, 2009 at 12:28 PM, Walt
> Welton-Lair<walt.welton-lair at autodesk.com> wrote:
>> "Proposed solution: Add support to the rendering engine to render
>> layer styles in ordered passes."
>> I'd like to see some concrete suggestions in the RFC on how to
>> actually do this efficiently. Just consider a conservative use
>> case - say around 10 rules.
>> Walt
>> Sent: Thursday, June 25, 2009 9:29 PM
>> Subject: [mapguide-internals] MapGuide RFC 69 - Rendering Layer
>> I have posted a new RFC
>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc69
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> +61 405 847 168
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the mapguide-internals
