[mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles
using Style Order
Zac Spitzer
zac.spitzer at gmail.com
Thu Jun 25 23:16:22 EDT 2009
what if features could be selected with an order by clause?
On Fri, Jun 26, 2009 at 1:06 PM, Walt
Welton-Lair<walt.welton-lair at autodesk.com> wrote:
> "Can some elaborate on how the server currently handles this?"
> Handles what?
> The current code iterates once over the features (ignore the compound line style example). For every feature it evaluates the filters defined by the rules (in the order that the rules are specified). Once it finds a matching rule it applies its style to the feature.
> With compound line styles we make a pass over all the features for each line style. So for a compound line style containing M styles we make M FDO queries.
> With rendering passes (RFC 29) we also iterate over all the layer's features for each rendering pass. The more passes you define the more queries you make.
> How to implement your RFC?
> option 1
> - Make a pass over the features for each rule.
> - During each pass only render the features that satisfy the rule for that pass.
> - If there are M rules you will make M FDO queries.
> => performance (speed) will be unacceptable for anything more than a few themes
> option 2
> - Make one query against all the features, remembering (in memory?) all the feature information (attributes / geometry) needed by stylization.
> - During the initial pass render the features for the first rule.
> - Iterate over the remaining rules in order, rendering the features for each rule.
> => performance (memory use) will be unacceptable for data sources containing large numbers of features
> => this approach goes against the MG architecture of not keeping feature data in memory during stylization (we already break that rule with labels which is what leads to high memory usage spikes for some maps)
> option 3
> - Allocate one image per rule.
> - Make one query against all the features, and render each feature into the image corresponding to the rule it satisifes.
> - Merge all images at the end.
> => performance (speed + memory) will be unacceptable for anything more than a few themes
> option 4
> ________________________________________
> From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
> Sent: Thursday, June 25, 2009 10:36 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles using Style Order
> At the moment the only way to achieve this is to split the road network out into
> multiple layers which is rather ugly.
> Taking a road network as the example here, it's only at the
> intersections where this
> problem occurs.
> z
> On Fri, Jun 26, 2009 at 12:28 PM, Walt
>> "Proposed solution: Add support to the rendering engine to render layer styles in ordered passes."
>> I'd like to see some concrete suggestions in the RFC on how to actually do this efficiently. Just consider a conservative use case - say around 10 rules.
>> Walt
>> Sent: Thursday, June 25, 2009 9:29 PM
>> Subject: [mapguide-internals] MapGuide RFC 69 - Rendering Layer Styles using Style Order
>> I have posted a new RFC
>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc69
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals
