[mapguide-internals] Installer stuff... thoughts about Apache
crash?
Jackie Ng
jumpinjackie at gmail.com
Fri Mar 6 03:02:27 EST 2009
Is mod_mgmapagent.so in the Apache/modules folder in the installation?
- Jackie
Jason Birch wrote:
> Trac is down; thought I'd post this before I nodded off and forgot.
> 1. PHP stuff:
> In php.ini:
> [PHP]
> extension_dir = "C:\Program Files\OSGeo\MapGuide Web\Php\ext"
> [Session]
> session.save_path = "C:\Temp"
> where both of those would be replaced with appropriate vars.
> C:\Program Files\OSGeo\MapGuide Web\Php should be added to the system
> PATH.
> Or are we supposed to be using php_MapGuideApiEnvConfig.dll as the PHP
> extension now, instead of php_MapGuideApi.dll ?
> 2. Apache problems
> Apache on its own and with the PHP API works great. I can get into the
> MapAdmin, and do all kinds of cool stuff. However, as soon as I hit the
> mapagent.fcgi Apache crashes. Are we missing something from the
> mod_mapguide configuration? Has something changed? Is there a difference
> between the headers that the module is built with and the distributed
> Apache binary? If anyone is brave and wants to take a look at this, the
> current installer (built by me) will be here in about 20 minutes:
> http://www.jasonbirch.com/temp/mginstall/MapGuideOpenSource-2.1.0-Unofficial.msi
> <http://www.jasonbirch.com/temp/mginstall/MapGuideOpenSource-2.1.0-Unofficial.msi>
> I've attached the httpd.conf that I'm working with (it's not
> autogenerating yet), and you'll have to manually set the PHP values above
> as well as the MENTOR_DICTIONARY_PATH env var.
> Man, this thing is so close I can taste it... Jackie's going great guns;
> awesome work!
> Jason
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-stuff...-thoughts-about-Apache-crash--tp2434405p2434437.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
