[mapguide-internals] Installer stuff... thoughts about Apachecrash?
Jackie Ng jumpinjackie at gmail.com
Fri Mar 6 09:28:43 EST 2009
Yes I get this too now. I notice if I try to run httpd.exe that it will error
saying that it can't load mod_mgmapagent.so
More missing files?
- Jackie
Jason Birch wrote:
> I think so, but its a dll not a so?  I likely won't get back to my install
> PC to check for at least 20 hours :(
> ----- Original Message -----
> From: mapguide-internals-bounces at lists.osgeo.org
> <mapguide-internals-bounces at lists.osgeo.org>
> To: mapguide-internals at lists.osgeo.org
> <mapguide-internals at lists.osgeo.org>
> Sent: Fri Mar 06 00:02:27 2009
> Subject: Re: [mapguide-internals] Installer stuff... thoughts about
> Apachecrash?
> Is mod_mgmapagent.so in the Apache/modules folder in the installation?
> - Jackie
> Jason Birch wrote:
>> Trac is down; thought I'd post this before I nodded off and forgot.
>> 1. PHP stuff:
>> In php.ini:
>> [PHP]
>>   extension_dir = "C:\Program Files\OSGeo\MapGuide Web\Php\ext"
>> [Session]
>>   session.save_path = "C:\Temp"
>> where both of those would be replaced with appropriate vars.
>> C:\Program Files\OSGeo\MapGuide Web\Php should be added to the system
>> PATH.
>> Or are we supposed to be using php_MapGuideApiEnvConfig.dll as the PHP
>> extension now, instead of php_MapGuideApi.dll ?
>> 2. Apache problems
>> Apache on its own and with the PHP API works great.  I can get into the
>> MapAdmin, and do all kinds of cool stuff.  However, as soon as I hit the
>> mapagent.fcgi Apache crashes.  Are we missing something from the
>> mod_mapguide configuration?  Has something changed?  Is there a
>> difference
>> between the headers that the module is built with and the distributed
>> Apache binary?  If anyone is brave and wants to take a look at this, the
>> current installer (built by me) will be here in about 20 minutes:
>> http://www.jasonbirch.com/temp/mginstall/MapGuideOpenSource-2.1.0-Unofficial.msi
>> <http://www.jasonbirch.com/temp/mginstall/MapGuideOpenSource-2.1.0-Unofficial.msi>
>> I've attached the httpd.conf that I'm working with (it's not
>> autogenerating yet), and you'll have to manually set the PHP values above
>> as well as the MENTOR_DICTIONARY_PATH env var.
>> Man, this thing is so close I can taste it...  Jackie's going great guns;
>> awesome work!
>> Jason
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> http://n2.nabble.com/Installer-stuff...-thoughts-about-Apache-crash--tp2434405p2434437.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/Re%3A-Installer-stuff...-thoughts-about-Apachecrash--tp2434476p2436006.html
More information about the mapguide-internals mailing list
