[mapguide-internals] About the WiX installer
Jackie Ng
jumpinjackie at gmail.com
Fri Mar 6 13:01:34 EST 2009
Yeah, I left out the ampersand in my conditions XD It's all working now.
Apache still won't run though because of mod_mgmapagent.
- Jackie
Jason Birch wrote:
> Cool...
> If you look at the server custom action invocation (in the
> Installers/Mapguide/ dir I think), there is a condition there to change
> what happens on install/uninstall; should be able to use this to limit
> apache CA.
> I wonder if WiX has an easy way of inserting a RunOnce as a CA to defer
> the server install until the reg key is set...
> I think Kenneth was looking at IIS config. Should be able to rev-eng a
> clean IIS install using ?heat.exe?
> J
> ----- Original Message -----
> From: mapguide-internals-bounces at lists.osgeo.org
> <mapguide-internals-bounces at lists.osgeo.org>
> To: mapguide-internals at lists.osgeo.org
> <mapguide-internals at lists.osgeo.org>
> Sent: Fri Mar 06 07:01:11 2009
> Subject: Re: [mapguide-internals] About the WiX installer
> Update:
> 1. MENTOR_DICTIONARY_PATH is now set properly. Reboot is required to take
> effect though.
> 2. MapGuide service installs and runs (as a result), but it only starts
> running after a reboot.
> 3. Added and customised the apache custom action supplied by Autodesk.
> 3.1. httpd.conf has all its templated values plugged in during
> installation.
> 3.2. php.ini has all its templated values plugged in during installation.
> 4. Apache service installs, but does not run (a problem with
> mod_mgmapagent.so)
> Problems:
> 1. Apache doesn't run (problem with mod_mgmapagent.so)
> 2. Apache custom actions also run when uninstalling.
> Still Todo:
> 1. IIS configuration. Will try to use what's supplied in Wix. Will only
> use
> the Autodesk supplied ones as a last resort.
> 2. Custom UIs to change install properties.
> - Jackie
> Jackie Ng wrote:
>> Hi All,
>> I'm trying to grok the WiX installer files. When trying to build the wix
>> installers, it is erroring out because it can't find a whole load of
>> files.
>> Given a checkout of the mapguide svn trunk, what do I need to do to
>> ensure
>> the wix installers build without problems?
>> - Jackie
> http://n2.nabble.com/About-the-WiX-installer-tp2339047p2436177.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/About-the-WiX-installer-tp2339047p2437162.html
More information about the mapguide-internals
