[mapguide-internals] About the WiX installer
Jackie Ng
jumpinjackie at gmail.com
Wed Mar 11 19:17:03 EDT 2009
All good now, for some reason an old copy of mod_mgmapagent.so was being kept
in the installer support files which overwrote the newer one when the
build.bat is preparing the staging area.
- Jackie
Tom Fukushima wrote:
> Hi Jackie,
> I am using Apache2.2.4 with mod_mgmapagent.so (build using VS2008) without
> problems. If you are using the same version of Apache it should also
> work.
> Make sure the following lines are in your httpd.conf, otherwise the module
> won't load:
> LoadFile ../Php/php5ts.dll
> LoadFile ../Php/ACE.dll
> LoadFile ../Php/MgFoundation.dll
> LoadFile ../Php/MgGeometry.dll
> LoadFile ../Php/MgHttpHandler.dll
> LoadFile ../Php/MgMapGuideCommon.dll
> LoadFile ../Php/MgMdfModel.dll
> LoadFile ../Php/MgMdfParser.dll
> LoadFile ../Php/MgPlatformBase.dll
> LoadFile ../Php/MgWebApp.dll
> Put these lines before the Dynamic Shared Object/LoadModule section.
> Tom
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Tuesday, March 10, 2009 6:11 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: Re: [mapguide-internals] About the WiX installer
> Update time:
> 1. I've added the IIS and IIS7 custom actions supplied by Autodesk. IIS7
> custom actions has not been integrated into the installer yet.
> 2. You should now be able to have an IIS-specific configuration and a
> Apache-specific configuration. If you msiexec the installer from the
> command-line setting MGWEB_CONFIG=IIS|APACHE, you should get certain
> features enabled and disabled. eg. If MGWEB_CONFIG=IIS, the apache web
> server will be disabled. This means we should now be able to toggle this
> value (and the affected features) via a custom dialog (yet to be done).
> 3. IIS configuration is slightly better than Apache. With IIS, php works
> and
> the mapagent works, but only through mapagent.exe (ie.
> http://localhost/mapguide/mapagent/mapagent.exe?OPERATION=...). The
> isapi_mapagent.dll handler seems to be properly mapped, but does nothing.
> I
> get login failed with Site Administrator.
> 4. Fixed a small issue with php.ini, there was a bug in the templating of
> the file, resulting in a bogus php extension path. Also the installer now
> writes the PHP path to the registry so it now knows where to look for
> php.ini
> The pressing issues at hand:
> 1. The mapagent. I can't find out if it works for Apache because it cannot
> load mod_mgmapagent.so and it is only working in IIS if you are using the
> executable (mapagent.exe) in your mapagent calls.
> I have a small theory about why it won't load on Apache. Maybe it is
> because
> the mod_mgmapagent.so module was built with Visual Studio 2008, but the
> Apache web server binaries may have been built with something else? Would
> this make the apache module incompatible?
> - Jackie
> http://n2.nabble.com/About-the-WiX-installer-tp2339047p2454788.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/About-the-WiX-installer-tp2339047p2464421.html
More information about the mapguide-internals
