[mapguide-internals] My MSI Install Issues
Jason Birch
Jason.Birch at nanaimo.ca
Mon Mar 16 14:17:58 EDT 2009
I'm seeing rollbacks too in a recent build of the installer. Haven't run with logging enabled yet, but it looks similar to what you're seeing.
Jason
Sent: Mon 2009-03-16 11:00 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] My MSI Install Issues
Got another MSI today but can't get it to install... it rollsback at the end
of the web services file-copy so I have two issues (logs are from the MSI
install).
1) Server Only Install
Looks like I am missing the service registration element?
Info 1721. There is a problem with this Windows Installer package. A program
required for this install to complete could not be run. Contact your support
personnel or package vendor. Action: MgServerInstallCA, location: C:\Program
Files\OSGeo\MapGuide Server\bin\mgserver.exe, command: install "MapGuide
Server 2.1"
2) Web Server Extensions (.net Only)
Gets so close... it's a bit harsh doing a complete rollback if the config
fails - looks like there are things that try to run and fail even if I
select to do a manual configuration.
Action start 10:28:03: InstallFinalize.
Action ended 10:28:19: InstallFinalize. Return value 3.
Action ended 10:28:21: INSTALL. Return value 3.
Action ended 10:28:21: ExecuteAction. Return value 3.
Action start 10:28:21: FatalError.
Action ended 10:28:32: FatalError. Return value 2.
Action ended 10:28:32: INSTALL. Return value 3.
=== Logging stopped: 3/16/2009 10:28:32 ===
MSI (c) (E4:B4) [10:28:32:168]: Product: MapGuide Open Source 2.1 --
Configuration failed.
More information about the mapguide-internals
