[mapguide-internals] My MSI Install Issues
Crispin_at_1Spatial
crispin.hoult at 1spatial.com
Mon Mar 16 14:00:12 EDT 2009
Got another MSI today but can't get it to install... it rollsback at the end
of the web services file-copy so I have two issues (logs are from the MSI
install).
1) Server Only Install
Looks like I am missing the service registration element?
Info 1721. There is a problem with this Windows Installer package. A program
required for this install to complete could not be run. Contact your support
personnel or package vendor. Action: MgServerInstallCA, location: C:\Program
Files\OSGeo\MapGuide Server\bin\mgserver.exe, command: install "MapGuide
Server 2.1"
2) Web Server Extensions (.net Only)
Gets so close... it's a bit harsh doing a complete rollback if the config
fails - looks like there are things that try to run and fail even if I
select to do a manual configuration.
Action start 10:28:03: InstallFinalize.
Action ended 10:28:19: InstallFinalize. Return value 3.
Action ended 10:28:21: INSTALL. Return value 3.
Action ended 10:28:21: ExecuteAction. Return value 3.
Action start 10:28:21: FatalError.
Action ended 10:28:32: FatalError. Return value 2.
Action ended 10:28:32: INSTALL. Return value 3.
=== Logging stopped: 3/16/2009 10:28:32 ===
MSI (c) (E4:B4) [10:28:32:168]: Product: MapGuide Open Source 2.1 --
Configuration failed.
View this message in context: http://n2.nabble.com/Installer%3A--Yeah-baby%21-tp2464815p2487545.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
