[mapguide-internals] My MSI Install Issues
Jason Birch
Jason.Birch at nanaimo.ca
Tue Mar 17 15:50:28 EDT 2009
After applying the patch, did you also remove the two lines from the
MsvcRuntime.wxi file that attempt to load the MFC msm? I think there
was some kind of conflict there; after I modified it locally so that
this include only loads the CRT msm, it ran through for me without
having to pre-install the redistributable.
Jason
-----Original Message-----
Sent: March-17-09 12:32 PM
To: mapguide-internals at lists.osgeo.org
Subject: RE: [mapguide-internals] My MSI Install Issues
I found the same thing on Win2k8 / IIS7 but didn't have time again today
to
try a manual fix - just got no sessions created with the FCGI agent.
I patched my copy of the installer using your 911 fix but still got
rollback
issues on a clean(ish) machine. However, when I ran the EXE of the
MFC/VS
runtime first the install completed so there may still be issues with
the
config on that front.
Look forward to the next installment...
More information about the mapguide-internals
