[mapguide-internals] Installer - work in progress
Jackie Ng jumpinjackie at gmail.com
Mon Mar 23 19:51:40 EDT 2009
Currently it's just a setting in the wix installer that prompts for a reboot.
<br><br>But I've noticed in test runs with the reboot requirement disabled, that the mapguide server will refuse to start, claiming it can't find the CS dictionaries, even though I have set the MENTOR_DICTIONARY_PATH environment variable.
<br><br>- Jackie
<br><br><blockquote class="quote light-black dark-border-color"><div class="quote light-border-color">
<div class="quote-author" style="font-weight: bold;">zspitzer wrote:</div>
<div class="quote-message shrinkable-quote">A complete uninstall and then deleting the left over dirs resolved
<br>that problem for me...
<br><br>what causes the requirement for a reboot out of interest?
<br><br>is it the environment vars? if we could avoid the reboot it would be golden :)
<br><br>z
<br><br>On Tue, Mar 24, 2009 at 9:58 AM, Jason Birch &lt;Jason.Birch at nanaimo.ca&gt; wrote:
<br>&gt; Is anyone else who is testing the 2.1 installer with IIS having difficulty creating a new DataConnection in Maestro?  In my case, it's crashing out the ISAPI handler, without any error messages other than connection closed.
<br>&gt;
<br>&gt; Note, that for IIS7 install, you have to manually register the .json (application/json) MIME type, and probably convert mapviewerajax into an application in order to get previews working.  I haven't seen the ConfigurationException problem since I did that; not stating causality here though :)
<br>&gt;
<br>&gt; Jason
<br>&gt;
<br>&gt; -----Original Message-----
<br>&gt; From: Jason Birch
<br>&gt; Sent: March-23-09 12:35 PM
<br>&gt; To: 'MapGuide Internals Mail List'
<br>&gt; Subject: RE: [mapguide-internals] Installer - work in progress
<br>&gt;
<br>&gt; I've seen this too.
<br>&gt;
<br>&gt; On my W2k8 install, I did a full install, loaded the Sheboygan samples, then used Maestro to try and preview the Aqua template.  I believe that this message may come up because my repository is corrupted; the first couple times I was able to bring the server back up by deleting the dbxml repositories and restarting the server.  The last time, this didn't work; I kept getting the error message below.
<br>&gt;
<br>&gt; Jason
<br>&gt;
<br>&gt; From: Zac Spitzer
<br>&gt; Sent: March-17-09 8:35 PM
<br>&gt; To: MapGuide Internals Mail List
<br>&gt; Subject: Re: [mapguide-internals] Installer - work in progress
<br>&gt;
<br>&gt; on a standard bundled install with this installer on xp sp3 I get
<br>&gt;
<br>&gt; Configuration Exception: /webconfig.ini (twice)
<br>&gt;
<br>&gt; from a mapagent request for a tile
<br>&gt; _______________________________________________
<br>&gt; mapguide-internals mailing list
<br>&gt; mapguide-internals at lists.osgeo.org
<br>&gt; <a href="http://lists.osgeo.org/mailman/listinfo/mapguide-internals" target="_top" rel="nofollow">http://lists.osgeo.org/mailman/listinfo/mapguide-internals</a><br>&gt; _______________________________________________
<br><br><br><br>--
<br>Zac Spitzer -
<br><a href="http://zacster.blogspot.com" target="_top" rel="nofollow">http://zacster.blogspot.com</a><br>+61 405 847 168
<br>_______________________________________________
<br>mapguide-internals mailing list
<br>mapguide-internals at lists.osgeo.org
<br><a href="http://lists.osgeo.org/mailman/listinfo/mapguide-internals" target="_top" rel="nofollow">http://lists.osgeo.org/mailman/listinfo/mapguide-internals</a></div>
</div></blockquote>
View this message in context: http://n2.nabble.com/Installer---work-in-progress-tp2493651p2524060.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
