[mapguide-internals] Installer - work in progress
Zac Spitzer
zac.spitzer at gmail.com
Mon Mar 23 19:29:24 EDT 2009
A complete uninstall and then deleting the left over dirs resolved
that problem for me...
what causes the requirement for a reboot out of interest?
is it the environment vars? if we could avoid the reboot it would be golden :)
z
On Tue, Mar 24, 2009 at 9:58 AM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> Is anyone else who is testing the 2.1 installer with IIS having difficulty creating a new DataConnection in Maestro? In my case, it's crashing out the ISAPI handler, without any error messages other than connection closed.
> Note, that for IIS7 install, you have to manually register the .json (application/json) MIME type, and probably convert mapviewerajax into an application in order to get previews working. I haven't seen the ConfigurationException problem since I did that; not stating causality here though :)
> Jason
> -----Original Message-----
> From: Jason Birch
> Sent: March-23-09 12:35 PM
> To: 'MapGuide Internals Mail List'
> Subject: RE: [mapguide-internals] Installer - work in progress
> I've seen this too.
> On my W2k8 install, I did a full install, loaded the Sheboygan samples, then used Maestro to try and preview the Aqua template. I believe that this message may come up because my repository is corrupted; the first couple times I was able to bring the server back up by deleting the dbxml repositories and restarting the server. The last time, this didn't work; I kept getting the error message below.
> Jason
> From: Zac Spitzer
> Sent: March-17-09 8:35 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] Installer - work in progress
> on a standard bundled install with this installer on xp sp3 I get
> Configuration Exception: /webconfig.ini (twice)
> from a mapagent request for a tile
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
