[mapguide-internals] Installer testing
Jason Birch Jason.Birch at nanaimo.ca
Sat Mar 28 16:25:45 EDT 2009
I think I'm running 1.6.12 (or something like that) on the work PC where I built MapGuide.
Maybe I need to downgrade?  I am Java-clueless.
Jason
________________________________________
Sent: Saturday, March 28, 2009 11:52 AM
Subject: Re: [mapguide-internals] Installer testing
I found another problem with Java version. When I try to preview for example one layer with maestro, I get a java error:
It seems that maybe there is a problem with the jdk version. What JDK version was used to compile the java api? Searching on the net, people say that this problem comes when the jre compiler version is not the same than the running jre version.
More information about the mapguide-internals mailing list
