[mapguide-internals] new projection in csmap
Hugues Wisniewski
hugues.wisniewski at autodesk.com
Mon May 4 12:58:19 EDT 2009
For info, this system will soon be added to the CsMap coordinate system dictionaries.
If I'm not mistaken this the EPSG system 3785:
http://spatial-reference.org/ref/epsg/3785/
CsMap already has the logic to work with this system, that's why this WKT can be understood by CsMap and can work with MapGuide but in case one wants to directly with this system using the MgCoordinateSystem API and load it from the dictionaries, this is not possible at the time.
When the system will be added this will become possible.
I don't know yet when exactly this is going to happen. I'd say it's a question of weeks.
This will come with an EPSG update that is being under development on the CsMap project.
Hugues
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul Spencer (External)
Sent: Wednesday, April 29, 2009 5:10 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] new projection in csmap
Zak and I have it working now to specify a google layer and a mapguide
MapDefinition as an overlay in Fusion. Instructions are being
prepared, we'll let you know as soon as its up (will require trunk
fusion because there were some necessary changes)
Cheers
Paul
On 29-Apr-09, at 5:27 PM, Jason Birch wrote:
> Yes... assuming that all of your existing data sources have
> coordinate systems defined, and that CS-Map is able to project
> between them and the popular vis CS.
> That's how the enterprise.mapguide.com example is doing it. Their
> source data is the standard Sheboygan data in LL84.
> http://tinyurl.com/cy5wer (MapDefinition - just use Anonymous user,
> no password)
> More info on the enterprise.mapguide.com implementation:
> http://n2.nabble.com/re%3A-flexible-web-layouts-tp2660073p2661342.html
> I tried getting a Google Maps layer to work by adding it to an
> ApplicationDefinition based on the info in the Mike's blog:
> http://research.dmsolutions.ca/?p=314
> But wasn't able to get both the MapGuide and Google Maps layers to
> initialize when part of the same map. I actually prefer the MGE
> demo implementation because it also includes a Google layer-type
> switcher. I could see extending this switcher to allow me to choose
> between Google layers and also MapGuide HTTP tile layers on all of
> my maps.
> Jason
> From: Paul Spencer
> Sent: Wednesday, April 29, 2009 2:04 PM
> That works. Should it work if I do that on a MapDefinition (will it
> convert all the layer definitions on the fly)?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
More information about the mapguide-internals
