[mapguide-internals] Another installer test...
Jackie Ng jumpinjackie at gmail.com
Thu May 7 22:19:18 EDT 2009
I do believe "MapGuide Web" was the old directory of the web extensions
before we decided on a different directory structure. Perhaps the IIS7
action has not taken in this new directory structure?
- Jackie
cagray wrote:
> Hi,
> I have used the 0.6 installer on Vista (32bit) using .NET and it works
> fine as far as i can see. One minor point is that there appears to be a
> mistake entry in IIS. The mapviewernet folder is pointing to:
> MapGuide Web\www\....
> instead of:
> MapGuide\Web\www\....
> Thanks
> Colin
View this message in context: http://n2.nabble.com/Another-installer-test...-tp2776791p2843203.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
