[mapguide-internals] MIME type for MapGuide packages
Jason Birch
Jason.Birch at nanaimo.ca
Sat May 9 23:19:05 EDT 2009
Hi all,
Currently, without a MIME type defined for mapguide packages, Internet Explorer interprets them as .zip files, causing confusion and questions by new users.
One way of dealing with this would be to register a MIME type for MapGuide packages with IANA as documented in the vendor tree section of following RFC:
http://www.ietf.org/rfc/rfc4288.txt
Specifically, I'd propose something like:
application/vnd.osgeo.mapguide.package mgp
An alternative to this would be to encourage users to configure their http servers to deliver mapguide packages with an existing standard MIME type:
application/octet-stream mgp
This may be more appropriate, since MapGuide doesn't directly interact with the packages; they require user action once downloaded to be used.
I'm OK with either solution, but would like feedback so that we can either proceed with the registration or with documenting the preferred solution on the wiki. Once I get some feedback, I'll take care of the registration (if required), having the OSGeo download server configured to implement the chosen solution, and documenting the chosen approach on the wiki.
Jason
More information about the mapguide-internals
