[mapguide-internals] Another installer test...
Jason Birch Jason.Birch at nanaimo.ca
Tue May 12 18:58:48 EDT 2009
Simon Pelicon wrote:
>    I noticed some minor issues. Initial file unpacking files was a bit
> slow and
>    i think that calculated disk usage was wrong (it required 1.4 GB of
> disk )
Yes, the unpacking time is because we're using the maximum compression
options to keep the download size as small as possible.
The calculated disk use is accurate but transient; it actually uses about
900MB during installation for two uncompressed copies of the MSI.  I have no
idea why this is.
View this message in context: http://n2.nabble.com/Another-installer-test...-tp2776791p2875142.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
