[mapguide-internals] RE: Another installer test...
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed May 13 03:46:06 EDT 2009
After installing on Win 2K3 R2, with IIS ASP.Net,
the mapagent has "integrated authentication" enabled, which causes all
requests to be denied (authentication failed).
I'm not sure why that is enabled, or if its fixable in the installer.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jason Birch skrev:
> Oh...
> I forgot to say that this build also includes:
> - Trevor's recent fixes for the HTTP connection
> - Bruce's fixes for the fdo connection problems (mostly evident in GDAL)
> - Walt's optional optimizations for dealing with thick lines
> Lots of goodies in there to look at when you get a successful install. If you've been having stability problems, this is definitely worth trying out.
> Jason
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
