[mapguide-internals] Initial RC1 Build?
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Wed Nov 4 08:32:47 EST 2009
Sounds the same - I didn't get a screen grab.  Will try and find another
machine.
I know build "3981 (Beta1)" did **not** have the problem on at least 5
Win2k3 servers so it maybe just development XP boxes that are affected.  If
the installer logic has not changed since 3981 it should be OK on Servers
and add a comment in release notes for XP referencing ticket 1059.
Jackie Ng wrote:
> Is is something like this?
> http://trac.osgeo.org/mapguide/ticket/1059
> I just built and tested an installer from my current 2.1 working copy. I
> got a yes/no reboot dialog (as expected). I never got forced into a
> reboot.
> - Jackie
> Crispin_at_1Spatial wrote:
>> Jackie,
>> As is implied in Kenneth's reply, it is not the reboot that is the
>> problem - I can schedule that and cope with the need.  Why reboot?...
>> IISRESET picks up most changes - is it the service needing the PATH
>> change for CS-Map?  I would have thought this was picked up on the
>> service restart...
>> Anyway I digress... the issue with the RC1 installer is that there is no
>> warning or option, at the end of the install process the reboot kicks in.
>> You can sneakily leave an edited TXT file open in notepad to force a user
>> interface catch but ideally the installer should ask/warn.
>> Thanks - Crispin
>> Jackie Ng wrote:
>>> I've been thinking about this required reboot, and was wondering...
>>> How did installers pre-2.1 (2.0.x, 1.2, etc) get away without rebooting?
>>> Didn't they set a system environment variable as well (for Proj.4)?
>>> - Jackie
>>>> Hi - just to bring this up before the PSC meeting.
>>>> I have been using this version (2.1.0.4283-RC1.exe) in our classic .net
>>>> / IIS environment for a while now and looks good.
>>>> At the last meet there was to be a release before the end of October -
>>>> **please** follow the guidelines and launch 2.1 so that the effort can
>>>> move on, it's quite painful from this end you know...
>>>> The only thing is the installer does the rather harsh forced reboot at
>>>> the end without warning that on server environments is not ideal.
>>>>  Crispin
>>>> Jason Birch wrote:
>>>>> Hi all,
>>>>> Well, I got the build done, but did not get to do ANY testing on it;
>>>>> ran out
>>>>> of time if I want to be functional at work tomorrow.  Have uploaded
>>>>> here:
>>>>> http://download.osgeo.org/mapguide/testing/
>>>>> as: MapGuideOpenSource-2.1.0.4283-RC1.exe
>>>>> And the md5sum output is:
>>>>> c85fad1a8410988b37099ac307ca8b0f
>>>>> *MapGuideOpenSource-2.1.0.4283-RC1.exe
>>>>> Please try installing (on a non-production machine) if you have a few
>>>>> minutes, and once we get some hopefully positive notes we can move it
>>>>> into
>>>>> the release folder for 2.1.0.
>>>>> I was hoping to roll FDO 3.4.1 RC1 into this release, but fate was
>>>>> unkind :)
>>>>>  I did swap the SQLite provider for Traian's back-ported 3.4 version;
>>>>> if
>>>>> anyone has concerns with this I can put the original version back in,
>>>>> but it
>>>>> has some nasty bugs.
>>>>> Jason
>>>>> _______________________________________________
>>>>> mapguide-internals mailing list
>>>>> mapguide-internals at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Initial-RC1-Build-tp3767422p3945160.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
