[mapguide-internals] Mapguide ./configure on Linux, Makefile.in
files missing!
kernel_panic
sudoaptgetinstalld00d3 at gmail.com
Sun Nov 8 10:36:25 EST 2009
That worked! Thank you very much :)
However, now Im stuck with this :p
make[2]: se ingresa al directorio `/opt/MgDev/Common/Geometry'
make[2]: *** No hay ninguna regla para construir el objetivo
`../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a', necesario para
`libMgGeometry.la'. Alto.
make[2]: se sale del directorio `/opt/MgDev/Common/Geometry'
make[1]: *** [all-recursive] Error 1
make[1]: se sale del directorio `/opt/MgDev/Common'
make: *** [all-recursive] Error 1
Any clues on how to solve this? :p
2009/11/7, Walt Welton-Lair [via OSGeo.org]
<ml-node+3965848-1204655016 at n2.nabble.com>:
> Here's the steps I usually run (from the root folder):
> libtoolize --force
> aclocal
> automake --add-missing
> autoconf
> configure
> The automake step creates the Makefile.in files. I have never used cmake.
View this message in context: http://n2.nabble.com/Mapguide-configure-on-Linux-Makefile-in-files-missing-tp3965262p3968529.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
