[mapguide-internals] Mapguide ./configure on Linux, Makefile.in
files missing!
Walt Welton-Lair
walt.welton-lair at autodesk.com
Sat Nov 7 17:02:15 EST 2009
Here's the steps I usually run (from the root folder):
libtoolize --force
aclocal
automake --add-missing
autoconf
configure
The automake step creates the Makefile.in files. I have never used cmake.
Walt
________________________________________
From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of kernel_panic [sudoaptgetinstalld00d3 at gmail.com]
Sent: Saturday, November 07, 2009 1:45 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Mapguide ./configure on Linux, Makefile.in files missing!
Well... it's been a pain in the sit-part to build mapguide, but it seems
worth it :)
Im having troubles compiling it under linux for about a month now, and you
can follow the whole drama here
http://n2.nabble.com/FDO-Compile-error-libxalan-c-td3772060.html#a3772060
Now, my problem is the following
Im working with the /trunk version of mapguide, and I have already build the
webserver extensions, FDO and build_oem.sh script, however, when I run the
./configure script, it always stops with an error regarding Makefile.in
files not being present on their respectie folders, in short: there arent
ANY Makefile.in files on ANY Mapguide/trunk folders :p:p
Now, who/how can fix this? :P
View this message in context: http://n2.nabble.com/Mapguide-configure-on-Linux-Makefile-in-files-missing-tp3965262p3965262.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
