[mapguide-internals] RE: Rendering engine issue
Ivan Miličević
Ivan.Milicevic at supranet.hr
Tue Nov 17 03:46:01 EST 2009
Hello Kenneth,
Double checked; no double lines, single layer, clean lines, various line width, map space and device space units... The behaviour is same.
Scale is small, everything bellow 1:100000 (meters, projection is LL84 - WGS84) is falling apart. MG seems to be just fine (memory is fine) and error log is empty.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Tuesday, November 17, 2009 9:31 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] RE: Rendering engine issue
It seems as if there is a bug in the rendering engine.
Try adjusting the linewidth to see if it gets better.
Also make sure the line data is clean, eg. no double lines etc.
This is usually due to rounding errors, what scale are you zooming in at?
Anything below 1:50 makes my MapGuide use extreme memory and often crashes.
Regards, Kenneth Skovhede, GEOGRAF A/S
Ivan Miličević skrev:
> Anyone see this???
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Ivan Miličević
> Sent: Tuesday, November 10, 2009 1:18 PM
> Subject: [mapguide-internals] RE: Rendering engine issue
> Ok, I can't attach via Outlook so, here is a download link: http://gis.supranet.hr/downloads/mg.zip
> Sent: Tuesday, November 10, 2009 1:16 PM
> Sorry,
> here is attach.
> Subject: [mapguide-internals] Rendering engine issue
> Hello Internals,
> i have noticed a strange behaviour of rendering engine when zoom action is performed.
> Runned server is Mapguide 2.1 (Jason's ultra nightly beta build), OS is XPSP3 and browser is IE8.
> Everything is in swf file (captured flash movie), so please take a look.
> Should I open new a ticket for this issue?
> It's interesting that AutoCAD Map 3D had the same problem a year ago.
> Ivan Miličević
> voditelj odjela razvoja
> SUPRA NET d.o.o.
> Majstorska 5, 10000 Zagreb
> CROATIA
> Mobile: +385 (0)91 434-3940
> Office: +385 (0)1 434-3940
> Fax: +385 (0)1 434-3999
> Email: ivan.milicevic at supranet.hr
> URL: www.supranet.hr
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
