[mapguide-internals] RE: Rendering engine issue
Zac Spitzer
zac.spitzer at gmail.com
Tue Nov 17 03:56:03 EST 2009
what resolution is the data?
if you post a mgp to a trac ticket it would be great :)
z
2009/11/17 Ivan Miličević <Ivan.Milicevic at supranet.hr>
> Hello Kenneth,
> Double checked; no double lines, single layer, clean lines, various line
> width, map space and device space units... The behaviour is same.
> Scale is small, everything bellow 1:100000 (meters, projection is LL84 -
> WGS84) is falling apart. MG seems to be just fine (memory is fine) and error
> log is empty.
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede,
> GEOGRAF A/S
> Sent: Tuesday, November 17, 2009 9:31 AM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] RE: Rendering engine issue
> It seems as if there is a bug in the rendering engine.
> Try adjusting the linewidth to see if it gets better.
> Also make sure the line data is clean, eg. no double lines etc.
> This is usually due to rounding errors, what scale are you zooming in at?
> Anything below 1:50 makes my MapGuide use extreme memory and often crashes.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Ivan Miličević skrev:
> > Anyone see this???
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Ivan Miličević
> > Sent: Tuesday, November 10, 2009 1:18 PM
> > Subject: [mapguide-internals] RE: Rendering engine issue
> > Ok, I can't attach via Outlook so, here is a download link:
> http://gis.supranet.hr/downloads/mg.zip
> > Sent: Tuesday, November 10, 2009 1:16 PM
> > Sorry,
> > here is attach.
> > Subject: [mapguide-internals] Rendering engine issue
> > Hello Internals,
> > i have noticed a strange behaviour of rendering engine when zoom action
> is performed.
> > Runned server is Mapguide 2.1 (Jason's ultra nightly beta build), OS is
> XPSP3 and browser is IE8.
> > Everything is in swf file (captured flash movie), so please take a look.
> > Should I open new a ticket for this issue?
> > It's interesting that AutoCAD Map 3D had the same problem a year ago.
> > Ivan Miličević
> > voditelj odjela razvoja
> > SUPRA NET d.o.o.
> > Majstorska 5, 10000 Zagreb
> > CROATIA
> > Mobile: +385 (0)91 434-3940
> > Office: +385 (0)1 434-3940
> > Fax: +385 (0)1 434-3999
> > Email: ivan.milicevic at supranet.hr
> > URL: www.supranet.hr
> > mapguide-internals mailing list
> > mapguide-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
