[mapguide-internals] 2.1.0 Final Windows Installer
Crispin_at_1Spatial
crispin.hoult at 1spatial.com
Wed Nov 18 05:47:17 EST 2009
Thanks Jason,
I assume as you have retained .4283 in your build number that this did not
come from the up-to-date 2.1 branch. Can you confirm?
The only change between then and now is ticket 1107 AFAIK
http://trac.osgeo.org/mapguide/ticket/1107
http://trac.osgeo.org/mapguide/changeset/4339
Crispin
Jason Birch wrote:
> Hi all,
> I've uploaded what I hope is the final 2.1.0 windows installer:
> http://download.osgeo.org/mapguide/releases/2.1.0/MapGuideOpenSource-2.1.0.4283-Final.exe
> MD5 (also attached):
> f5b86032f72f242329450b16634abba7 *MapGuideOpenSource-2.1.0.4283-Final.exe
> This _should_ be equivalent to the RC, but with different "branding" in
> the
> installer.
> Could someone please announce, update web pages, etc? Make sure to
> mention
> that to install on 64bit IIS, user will need to manually set their app
> pool
> to 32bit mode.
> I've tested this install on W2k3 and it appears to install and load
> mapagent/mapadmin fine.
> I don't think we have an answer for Linux users other than SVN, which can
> be
> painful at times.
> Jason
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/2-1-0-Final-Windows-Installer-tp4023684p4024640.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
