[mapguide-internals] Re: 2.1.0 Final Windows Installer
Jason Birch
jason at jasonbirch.com
Thu Nov 19 20:44:05 EST 2009
Cool.
It would be great if we could post a tarball of the source checked out
on linux (I think line-endings etc change?).
Not sure if would be better to just zip up including .svn directories
(good starting point) or to export from local repo for a cleaner tree.
Maybe both :)
On 2009-11-19, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Hi Jason, I am updating the Drupal website. Should we also post the source
> code as we did for previous releases? I can perform the SVN checkout and
> zip locally assuming we are using version 4283.
> And thank you for your many tireless hours on this release!
> Regards,
> Trevor
> http://n2.nabble.com/2-1-0-Final-Windows-Installer-tp4023684p4034013.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
