[mapguide-internals] Re: 2.1.0 Final Windows Installer
Trevor Wekel
trevor_wekel at otxsystems.com
Thu Nov 19 21:26:05 EST 2009
Yep. Check out from Linux and run an svn export to create a clean tree. The line endings change and I think the Linux checkout also makes a difference on the execute permissions for the various shell scripts.
This might take me a couple of days. I don't have a Linux development environment set up at the moment. I should probably install VMware on my extra Dell box and go from there. Not a big deal. Just more busy work.
I wonder if we should leave the existing Windows build VM at 2.1 instead of moving it to 2.2? I suspect the community will want an MGOS 2.1 patch at some point.
Thanks,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: November 19, 2009 6:44 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Re: 2.1.0 Final Windows Installer
Cool.
It would be great if we could post a tarball of the source checked out
on linux (I think line-endings etc change?).
Not sure if would be better to just zip up including .svn directories
(good starting point) or to export from local repo for a cleaner tree.
Maybe both :)
On 2009-11-19, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Hi Jason, I am updating the Drupal website. Should we also post the source
> code as we did for previous releases? I can perform the SVN checkout and
> zip locally assuming we are using version 4283.
> And thank you for your many tireless hours on this release!
> Regards,
> Trevor
> http://n2.nabble.com/2-1-0-Final-Windows-Installer-tp4023684p4034013.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
